VINNIE IN MAKEUP!
Re: VINNIE IN MAKEUP!
Is it the Ankh or just the cross that was applied for months ago ?
Holding the carVIN ?!?!
Looks like a cross rather than an ankh. Keeps KISS Co away I guess. He looks pretty good here, his face looks thinner. Kudos.
Great to see the No.1 VVV in the light again too!
Wow, the Carvin is out!! Good to see it again. It was his favourite to play.
- wolfgang161272
great to see him in make up!!!
Wow
Wow
- Streetbeat
This is GREAT!!!!!!!
The Cross, the Carvin, the original VVI strap is back, and the chops i'm pretty sure they are back !!!!!!!!!
Now he needs an official photo session with his costume, this are the best VVI news since 1996.
THANK YOU VINNIE!
THANK YOU VINNIE!
- tukoztukoz
Let's get geeky...
Seems as if Vinnie had the wood under the Floyd cavitied out for better playability and ease of whammy damage.
I guess you could say he always had his Floyds set to "float" but the angle he had to set them at was going in the direction of a 45 degree angle from the body.
Now it is flat/parallel with the body.
I believe Jeff Beck still has that angle to his trems.
I still don't understand why he doesn't carve under his standard trem.
I believe he still uses the Fender 2 pivot posts ...
Maybe he switched back to the 6 screw trem.
- Attachments
- 20181027_143813.png (422.5 KiB) Viewed 2768 times
- tukoztukoz
The pink Jackson double V without strings he had on recent pics was cavitied out. Really ugly... On the Carvin there ´s no need to do that because of the angle between the neck and the body, which is not the case on strats. Or maybe a slight cavity for high trem bends .
6 screws trem? Oh, no! I’d be depressed if so !
I ´m still waiting for the return of the purple/silver repainted double V Jackson, the one with the shark inlays. THE Invasion guitar...
No need ?
IT'S CUT OUT !
IT'S CUT OUT !
Freegan love that Carvin.
Simply because I watched the REH video about 6000 times
The Carvin was always a recessed Floyd set up. Quite possible it was made with a regular Floyd and Vinnie/Bill put on one of the NFTs after it was delivered. But it definitely was a factory recess with pull up route, as were the Washburn and Ibanez versions. Unlike the Jackson VVVs and Rhoadses that were top mounted when made and a pull up route added later.
Yesterday I spent close to 3 hours with the V-Man at the Chiller Theater Expo, he was in great spirits and full of laugh & smiles....it was amazing to see him interact with the fan's and he was very accommodating to them in every way, especially one's that had some Physical Disabilities ! I brought him a "Group Photo" which consisted of 4 of his old neighborhood friends, some who he hadn't seen in over 20 yrs. who just so happened to be at a "Gig" I went to see, the night before....They all wanted me to say hello to Vinnie for them and I knew that after a few Beer's I'd probably forget most of their names, so I had them all write individual messages to Vinnie on the backside of the "Bar Coaster's" that you see here....The look on Vinnie's Face was "Priceless" and after reading each coaster he was truly lost for words....all I can tell you, is that they were all filled with Best Wishes and their Contact Info, naturally with respect I'm sorry, I can't share that with you....
- tukoztukoz
ALWAYS ?shramiac wrote: ↑Sun Oct 28, 2018 8:03 pm The Carvin was always a recessed Floyd set up. Quite possible it was made with a regular Floyd and Vinnie/Bill put on one of the NFTs after it was delivered. But it definitely was a factory recess with pull up route, as were the Washburn and Ibanez versions. Unlike the Jackson VVVs and Rhoadses that were top mounted when made and a pull up route added later.
The Carvin had a professional routing before the Metal Tech video but photos from the tour seem to tell a different story.
The Washburn(autographed photo) looks to have not been recessed.
I never noticed the routing before.
Big Ed,
I am so happy that you are able to share some authentic good will with Vinnie.
You are a good dude !
That is "feel good" stuff !!!!
Okay. Maybe not the Washburn. A higher res shot of the one you posted it looks like it is routed on the bottom but looking at the top side, it is indeed just a top mounted Floyd with no pull up.
I don’t like the Washburn now!
The Carvin would have to have been done when built as it would have meant that the post studs would have to be removed and the holes drilled deeper to accommodate for the route.
So how many Carvins were there? There's this white one from the Hot Licks video and the black one from the '89 Carvin catalog.
Any news on the signature guitars he had talked about a few months ago?
Do you have a pic of the 89 Carvin catalog?
We are only aware of one Carvin VVV.
No news lately of the new signature guitars.
Just one Carvin VVV.
The route is in the Love Kill & Time of Year vids too.
Yes. Just difficult to see... I guess
